- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Alfred.NESWADBAwrote:Hi,
>> When checking the size of the pdf in Adobe it's all good
Just a guess ... when you use Adobe on an English version of Windows, it will not report the size of the PDF as 297mm, it will report 11.7inch, doesn't it?
In Edit/Preferences you can set the Units under Units/Guides. Under Pages Display you can then set Always show doc page size. Then the actual size of the pdf is shown in the bottom left corner.
>> In this case it gets the height of 49.86 inches which is 297 mm.
Sorry, 49.86inch is not equal to 297mm.
49.86inch = 1266mm
Correct, my bad! It's 11.71 inch
>> My first batch contains 129 pdf's
How do you run the batch? Which tool do you use to do that and why can't that scale the imported PDF-page?
Maybe written unclear. I have a workload of 129 drawings that has to get the pdf exchanged for a new version.
Every drawing will be opened separately in order to secure that everything is ok.
- alfred -
