BeKirra
en respuesta a: Anonymous
What AutoCAD version are you with?
IMO it depends on the AutoCAD version you have. AFAIK "viewbase" is an AutoCAD native command and it works with my v2016.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
