- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi everyone,
just a quick question about a point that was raised at work. One of the guys at work seems to think that viewbase command wont work without Inventor and I thought I'll double check and see if anyone can confirm or advise otherwise.
Cheers
Elroy
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What AutoCAD version are you with?
IMO it depends on the AutoCAD version you have. AFAIK "viewbase" is an AutoCAD native command and it works with my v2016.
HTH
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Viewbase command and since ( AutoCAD 2012 ) can creates a base view from model space or Autodesk Inventor models. there is no need ( as a must ) for an Inventor program but it has the ability to work with Inventor Models . also you have to know that this command is available only on 64-bit systems.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
We use APDSU '15 release. We want to mix up our current available licenses with a few AEC options. In the AEC suite we wont have Inventor, but we will have AutoCAD included in the suite. From what I can tell on the forums it's been available since 2012. Its a command borrowed from Inventor but I wouldn't have thought it would be Inventor dependant. I've tried it a few years ago, but found it limited compared to Inventor.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for the response. I didn't think so, but thought I'll double check before I say anything. We'll try it out on a standalone AutoCAD install. Thanks for the pointing out that the command is only available on 64-bit machine.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes, it is good to know this command is only available on x64 system. Cheers.
(I also remember it is not available in v2011.)
X² + Y² = C²
