john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I copied the contents of your model to a new drawing and then imported the layouts from it as well using DesignCenter.  This now allows me to pick a scale from the Scale List. It appears that there is something wrong with the CANNOSCALE in the original file.
I did notice that I could set the Zoom scale manually (1/50xp) but the error remained with the scale list. I can dig deeper if necessary but this might be the easy fix.  Please take a look at the attached file and let me know it works for you. If it does, you will need to spend some time resetting some of the views.
John Vellek
