BranchEngineering
en respuesta a: ChrisRS
@ChrisRS- I downloaded and experimented with the free Bluebeam viewer.  It has the rotate option you mentioned and also an option for offsetting by X&Y values.  The rotate will get the plot and extra 2" in the desired relationship if printing using a 22x34 (Ansi D) paper size.  The offset will work if printing using a custom 22x36 paper size.  He hangup I can't seem to get past though is that Bluebeam seems to be cutting off a large strip from the top and bottom of the page.
Using the same 22x34 I printed from Adobe (with the 2" extra in the wrong place but all the drawing and border printed), I can't get Bluebeam to print all the sheet.  Even after I verified in the plotter properties dialog that the margins are set to 5mm, the print dialog shows a wide red band about 1.5" wide on the top and bottom of the sheet as if the pdf is more than 22".  I'd include screen snips but can't figure out how everyone else is pasting them into a message.
