2699 Vistas, 8 Respuestas
Cross polygon selection instead of lasso selection?
Hey!
Is there any way to customize the lasso selection with mouse and replace it with the cross polygon command?
As I use CPolygon much more...
If not, an alternative solution would be editing in-line command letters (pressing CP when using the SELECT command) with closer keystrokes.
Cheers!
