03-12-2018
12:24 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-12-2018
12:24 PM
Thanks Alfred - that has actually put me on the right track! If I unload my partial CUIX I can change the icons. But when I load my file, I can't. So obviously, it is something in my file - but how do I find out what? As far as I can tell, everything else is working fine (i.e., all my commands work)
I guess I was hoping that, knowing this happens immediately after I click an icon in the CUI icon grid for a command, and given this stack trace:
System.NullReferenceException: Object reference not set to an instance of an object. at Autodesk.AutoCAD.Customization.Revision..ctor(Revision rev) at Autodesk.AutoCAD.Customization.Macro..ctor(Macro macIn, MenuMacro par, Boolean preserveRevision) at Autodesk.AutoCAD.Customization.MenuMacro.duplicateMe(Macro mac) at Autodesk.AutoCAD.Customization.MainForm.buttonControlEventHandler(Object sender, ButtonControlEventArgs ea) at Autodesk.AutoCAD.Customization.ButtonControl.triggerEvent(ButtonControlAction action) at Autodesk.AutoCAD.Customization.ImageSelector.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I was hoping someone at AutoDesk might be able to give me some pointers....
I wonder if it makes a difference that MY icons are in a resource DLL?
