03-12-2018
03:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-12-2018
03:20 AM
In the target dwg, you can enter UNITS. You may have specified mm as the unit in the right listbox ?
In the dwg sources, the exact same parameter has to be set according to the "source of the source".
That is just in case your 3DS are transfered in a dwg before being inserted as blocks.
The best methods I would employ for that automatic purpose.
Edit : don't know if your 3DS objects come into autocad with a name block, it can't be the same name that you give to the dwg. by the way, ff they come as blocks, explode them and purge before you let them in a single dwg each.
