- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Waouu
That is the best accepted solution I ever had.
I really thank you
A button :
^c^c_circle
often includes the ESCAPE (it is there as "^c^c")
But if you want, you can prefix with *, it will apply the MULTIPLE command
So.
If you draw a line and want to stop for a cicle, CLICK the circle button with NO ESCAPE in between !
If you finished a circle, press ENTER to make another one.
If you were doing something else, and are free to hit a command, press C (Circle abbrev.)
Pretty fast ways, aren't they ?
About copying :
CP (in my language, check if it launches COPY in your Royal tongue) is a good way. But it is also a all command to learn (Press F1)
True : if you want to copy on itself it takes 3 ENTER, you need a macro if you do it all day.
But you can also click object(s), choose a blue grip and make it red and press ENTER as much as you want (look what it does) + a Copy option, etc...
You can make buttons, commands, personnalize (through a palette or the CUI command) :
'CIRCLERAD;50
'CIRCLERAD;10
*^c^c_circle;\;
[1 : sets future radius to 50, 2 : to 10, 3 : macros the fastest circle command you've ever seen, needs Escape to end]
Now that you know what we do of the soft, you know why it exists. It is a universal drawing board that you can (have to) manage your own way.
