4tpayne
1126 Vistas, 3 Respuestas
Table Identification
I'm trying to edit field values across drawings. When I copy tables from one drawing to the next the fields break because the reference cells from the previous drawing link to table identifiers such as table(%<\_ObjId xxxxxxxxxx>%). These table names seem to random generate when the table is created. Is there a way to custom name a table so no matter what drawing I place a table in the formulas within the cells will see the same value location?
Alfred.NESWADBA
en respuesta a: 4tpayne
fields are working with internal object-id's, so I guess (without development) you can't use virtual names as replacement and so copy them between different drawings.
Sorry, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Noah_GeorgeANSVN
Have we had any advancement on this? I'm having the same issue where I want to change the name of a table so it is easier to locate and reference.
imadHabash
en respuesta a: Noah_GeorgeANSVN
Would you make a new post with a full information about your issue please?
also, tell us what did you do to solve your issue.
Imad Habash
