- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hallo to everyone!!
i have downloaded some new hatches. When i activate the com and hatch and try to fill it into a rectangle it gives me the message more than 10000 hatch boundaries are selected.....You will see it to the pict.
is anyone that could give me an idea of the problem???
Thank you for your time !!! ![]()
Marianna
john.vellek has embedded your image(s) for clarity
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
i think that it's a zoom limits problem . try to put your needed hatch area zoomed in the screen and by minimum lines information ( turn off all unwanted layers ) and see if any changes.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I agree with Imad that you are likely seeing this message because you have so much turned on that the boundary detection is having issues. Try freezing everything except the boundary lines for the hatch and then try to apply it. If you would like to attach the hatch pattern and your drawing file, i am happy to try it on my computer too.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That alone will tax the command.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you a lot for your answer !!!
FInally i found the solution. Maybe it was about a zoom problem. I runed off all the layers and in the end it worked!!
Thank you ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your answer !!
It worked with that way!!!! Thank you !!!!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your answer !!!
No the problem was with the rectangle behind the box message !!! But maybe the many layers confused it !!
Now it works!
Thank you !!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sometimes if I have a big area that I want to hatch, so I can't zoom in far enough to exclude all the extra data. Instead of freezing a bunch of layers I just draw a few construction lines across the area I'm trying to hatch. Then I can hatch it in a few sections so I can zoom in tighter to avoid extra calculations for the hatch command. I then just delete my extra lines. It seems to help with areas I can't seem to get hatch to work correctly on. I have a lisp that combines the separate hatches back into one also. I don't really need to combine them but sometimes I do just to make the drawing neater.
Nick DiPietro
Cad Manager/Monkey
