- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @bespel,
I decided to start by showing you how to make a custom paper size in one of the default AutoCAD PDF PC3 files. It should be fairly similar process for most drivers but next week when you find out which plotter, we can tackle that individually if you get stuck.
At any rate, please review this quick video I made. I start PAGESETUP manager to create a custom one for this paper size. I select my PDF PC3 device and then go into Properties and then customize the paper size.
Next week, if you need help but you can always print to this PDF custom paper and then send the PDF to the printer/plotter. Some plot drivers have standard sheets set and others can auto-trim so those are settings you might need to adjust either at the piece of hardware or in the print driver.
I hope this helps.
John Vellek
