- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @jjamesPX7AM,
Thanks for your correspondence offline. I really found the video link useful in seeing some of the functionality that you are describing. While Revit would be much better suited to creating Families that would work similar to the VectorWorks, I think you can still get a lot of this done in AutoCAD too.
I made a quick video that shows a custom Mleader that allows you to indicate from centerpoints of the plants to the tag. You can also place the Mleader and move the label around the plant's trunk. Lastly, I show the results of a dataextraction that can count all of your plant blocks and even combine similar ones into a single row.
I hope this gets somewhat closer to what you are describing. Another method for the callout could be to integrate it into a dynamic block and perhaps set a visibility control to either show or hide the label.
Let me know please, if any of this is of interest and I can share or help get you started on creating such features for your process.
John Vellek
