02-26-2018
10:49 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-26-2018
10:49 PM
>> I found a lot of internet site but is not all object is dwg...
>> it is different format (.3ds .obj .max .fbx .c4d ect)
You can start command _IMPORT in AutoCAD, there you can see the file-types which can be imported (plus DXF, which can be opened or inserted directly like a DWG).
3DS and FBX is a good start, just keep in mind that most objects for rendering are based on meshes with high density, that could make DWG file quite big (and so slow for rendering).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
