Alfred.NESWADBA
en respuesta a: Anonymous
is that a XRef in your drawing or are the objects selectable line-by-line?
It might also be possible that there is transparency active (for objects/layers and activated on display).
So can you please create a new drawing, based on an original AutoCAD template and draw some lines, do they also look like faded?
If this only happens on this drawing then please upload this drawing so we can look into it.
If it is not drawing dependent create a new Windows user account, login with that account, start AutoCAD and see if new drawings also shows this issue.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
