en respuesta a: M_Hensley
@M_Hensley wrote:
To make a viewport with a hole in it make sure both your rectangles are closed polylines. Use REGION command to turn them both into regions. Use SUBTRACT command and select the outer then subtract the inner from it. This gives you a region with a hole in it. In viewport command use object option and select this region. Now you have a viewport with a hole in it.
Your comment so good, I screened it and "paste-specialed" it in the worksheet.
