02-23-2018
11:36 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-23-2018
11:36 AM
Hi @paulharlowm
Make sure that when you draw your geometry that you are using OSNAPs. I suggest that you should also not turn on too many at once.
To see the linework I used, you can select the 3dsolid and in the Solid Editing menu, select Extract Edges.
Here is some information on SURFSCULPT and MESHSMOOTH which you likely need to use at some point.
John Vellek
