Moshe-A
en respuesta a: spaulus
Steve,
if you only got 1 viewport i recomend inserting the block in model space cause there is always a chance by mistake that the viewport scale will be changed and you will loose the connection. even if you have 2 viewports with different scales i still say do the same
(as you are accustom to do without viewports)
moshe
