- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Placing a block in paperspace on drawing with vports?
I am a little oldschool and still don't have a complete understanding of paperspace vs modelspace and viewports.
I think i understand the concept but not sure how to use them properly.
I have been giving the task of adding "Piece marks" to some plans and elevations, the piece mark symbol we use is a rectangular box with a long number in it then a ellipse with a short number in it next to the rectangle, then you draw a leader between the rectangular box and a point on the pipe.
I am thinking that I can make the blocks and insert them in the paperspace so they will all be the same size? Will I be able to draw a leader across a viewport and point at a piece of pipe that is in modelspace?
Thanks for any comments.
Steve
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
not clearly understand your problem but you can use multileaders to anotate and snap its leader to any object in viewport from paperspace.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Steve,
if you only got 1 viewport i recomend inserting the block in model space cause there is always a chance by mistake that the viewport scale will be changed and you will loose the connection. even if you have 2 viewports with different scales i still say do the same
(as you are accustom to do without viewports)
moshe
