john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I worked with your data for a bit and can't duplicate what you are seeing.
Here are the steps I went through.
  • Opened the RCM file in ReCap Photo.
  • Exported as PTS file.
  • Opened Recap and started a new project
  • Imported my PTS file
  • I then save it as a RCP file.
  • I compared measuring the metal roof on the right side in both applications and they match.  The distance is in Meters.
  • Next I started a new AutoCAD dwg file and based it on the out-of-the-box metric template.
  • I use -dwgunits to set the file to use Meters for units.
  • Next I attach the point cloud in my drawing and measure the roof and again it matches.
I have done this three times with the same results.  Can you tell me what is different in your process?
John Vellek
