- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD draws excess lines when i create a section view using the command VIEWSECTION.
I've created a sample model to illustrate the problem.
It the first picture there is a view drawn by AutoCAD.
In the second picture there is a correct view.
How it can be solved?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I haven't tried this in a very long time so please forgive me if it takes a few tries. I created a model similar to your's and then created the views. For the section view I changed the Depth to a smaller value and those lines disappeared.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
^yes.
Also, if your example is typical of your usage, I would just use the 'Full' section instead of the 'Offset' section. However, if you typically have features that your section line goes to, then nevermind.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Unfortunately, It isn't the solution as you get the section, which is longer that the base view.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
In my example, the section is just displayed at a different scale. It is the same size as the original base.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Oh, I am sorry. I will check your solution in AutoCAD as soon as possible.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think it doesn't solve my problem. As i should use the orthogonal projection view type. (You use the normal one, if i'm not mistaken). Changing the the depth doesn't affect anything in my case.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Is it possible to share your drawing with me? I would like to see how it is behaving differently than my own.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Thanks for the file. Since I don't work in this discipline I reached out to another specialist. He told me that it is normal to see those jog lines as they indicate a jog has been made to creat the view. I hate the fact that one can't control how they look or turn them off easily. Removing the jog does remove the lines as they should but I understand that you are looking to hide them.
I am sorry if i mislead you with my previous response.
John Vellek
