02-22-2018
08:21 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-22-2018
08:21 AM
Odd.... couple things to try:
- Try to save to a name that isn't using 'spaces' within the file name (eg: Adroit_Design_2018_A2.dwg).
- Can you save this as a DWG? If so, copy the DWG and rename the extension to DWT
- Check with your local IT (or Systems Administrator) to ensure that your workstation is not locked down to the point that you cannot save files to your own machine (doubtful) but something to check; or can you save other files to the same location, such as Microsoft Word as an example.
- Are all the files your trying to save based off the same start-up template?
- Is this happening to only you, or to others in your office/company?
Chad Franklin
