- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Which system variable controls the toggle 'Uniform Scale' in the Insert dialog ?
I found a lot of posts regarding 'Uniform Scale' in a block defenition.
This is NOT what I am interested in !
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous
I think there isn't such system variable.
You can see the system variables concerning blocks here:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> Which system variable controls the toggle 'Uniform Scale' in the Insert dialog ? <<
There is NO system variable for this Uniform Scale ..
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think it just remembers the last setting, which means there may be a registry hack you can control it with, but not necessarily a system variable. is there a particular reason you are looking to control this box?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Its is controlled through a registry variable (value). You can preset it with a LISP code:
;enable Uni (defun c:InsUniform ( / profile) (vl-load-com) (setq profile (vla-get-ActiveProfile (vla-get-Profiles (vla-get-preferences (vlax-get-acad-object))))) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" profile "\\Dialogs\\insert_dialog") "ScaleUniformly" 1) ) ;disable Uni (defun c:InsNonUni ( / profile) (vl-load-com) (setq profile (vla-get-ActiveProfile (vla-get-Profiles (vla-get-preferences (vlax-get-acad-object))))) (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" profile "\\Dialogs\\Layerinsert_dialogDialog") "ScaleUniformly" 0) )
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
