3093 Vistas, 8 Respuestas
PCB Design using AutoCAD
I'm new to AutoCad tool assigned with the task of designing a PCB using AutoCad, So following are issue I'm facing right now:
1. To route a trace we are using lines instead is there any option to draw a path or anything similar?? As of now we need to draw two parallel lines to indicate a path.
2. There is no net connectivity i.e,. to have a virtual connectivity between two points with similar name. How can we establish a connectivity between two points as we do it in other tools like allegro
Mallikarjun
