- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Autocad Quick Select shortcut
Good afternoon. Is it possible to create a shortcut with a certain autocomplete in the Quick Select command? For example, a shortcut that selects all lines with a 45 ° angle. Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous
you can select the options like the pic.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello. Thank you for your attention. I know how to work with Quick Select. My question is whether there is a way to create a shortcut that does this automatically.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous
Sorry i misunderstand-ed you .
You can Use Lisp and AutoLisp files as @pendean said.
Look for the function of selection in LISP guide "SSget" and some other AutoLISP functions to filter your selection in AutoLISP and Visual LISP Guide. (VL-Functions).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Well, the angle of a line has to be tested after the ssget has done its job.
I would have suggested to use FILTER instead of the Quickselection thing but the angle is not present as a criteria.
And, unfortunatly too, FILTER is not scriptable.
It brings us to lisp.
(defun c:sang45(/ sel selout cont)
(sssetfirst nil)
(setq sel(ssget '((0 . "LINE")))
selout(ssadd)
cont 0)
(repeat(sslength sel)
(setq line(ssname sel cont))
(if(member(angle(cdr(assoc 10(entget line)))(cdr(assoc 11(entget line))))
(list (/ pi 4)(* 5(/ pi 4))))
(setq selout(ssadd line selout)))
(setq cont (1+ cont))
(sssetfirst nil selout)
(princ)
Just type sang45
(modified)
