- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Quick Properties not showing all information
I recently switched from using A360 to another cloud based file sharing system, pCloud, to share AutoCAD settings between AutoCAD at work and at home. Soon after this, I noticed Quick Properties was not showing all of the information in pop up box, and later would show blank space below as if it had a set size of 22 lines. I also uninstalled A360 thinking it would speed up my laptop. Seeing that the two of these were done in the same day and an AutoCAD article "Properties palette does not show selection and is blank in AutoCAD" seemed to indicated uninstalling A360 could result in a problem with the properties palette, I reinstalled AutoCAD to no avail, and then preformed a uninstall and reinstalled a clean version.
The problem still persists. Please help.
Also, is there a way possible to back up the quick properties settings for which information is shown?
