PafecDOGS
1655 Vistas, 11 Respuestas
AutoCAD 2017 REVCLOUD command
Hi, I have an issue with our AutoCAD setup here at work ...
We created a stripped down CUI file a few years ago in AutoCAD 2015 (which we load in addition to the main default ACAD.CUI) which adds a tab with all our favourite commands on. We recently noticed some additions to the REVCLOUD command that were added in 2016 I think, with options to draw a rectangular or polyline revcloud. I wanted to add these to options to our existing rev cloud tools in our CUI file, and did so (the command line for the Rectangular option is shown in the screenshot attached).
The problem is if I use our newly created button, it doesn't work. Further investigation showed that when I used the button, the REVCLOUD command it executes doesn't have the extra options like R or P for Rectangle or Polyline, but if I type the REVCLOUD command in the command window, it does. It seems like our CUI file is running an older version of the command. Our main ACAD file always points to the default location as installed by AutoCAD, so I don't understand why the button seems to execute a diff command to what I type in the window!?
