injineri
en respuesta a: Anonymous
As I understand you want to plot from model space with window option from plot area. Then you should draw frame around the object with desired size and snap to that frame when window mode is activated. and frame size will be according paper on what you are trying to plot and with what scale. for example you want to plot 1:100 on A4, then frame size will be 297x210 rectangle scaled 100x. but be honest its better to plot from paperspace and scale from there as experienced users advise in upper comments :cara_con_una_leve_sonrisa:
