Johanna_Esteban
en respuesta a: Anonymous
The surface you want to make is a bit complex in shape, but you can try these options to create surfaces.
1. Create a solid with the shape you need and use EXPLODE to break it down, which will result in surfaces or maybe some region *.
2. Using EXTRUDE on a line, curve or polyline (not closed) results in a surface.
3. For more complex surfaces you can use one or more lines, arcs or polylines, facing each other and use LOFT by selecting one and then another to create a surface (view image).
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! :cara_guiñando_un_ojo:
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
