02-08-2018
10:30 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-08-2018
10:30 AM
ISAVEPERCENT is set to 100? Are you working through a VPN or is your network extraordinarily slow?
If not, try changing it to 0 on all systems and see if that prevents the problem from cropping up. Years ago that was responsible for corrupting some drawings.
Unfortunately I don't know of a way to fix a broken solid aside from recreating it. Even using SOLEDIT to CHECK it reports it as a good solid. If you RECOVER the file in 2017 it deletes the offending solids.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
