john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I would start by getting High Sierra installed and running.  It can take the entire drive volume.
When you install Bootcamp it will allow you to adjust the partition size to accommodate both Windows and the existing MacOS that you just installed. <Here is a nice tutorial on getting Bootcamp installed>
If you are running AutoCAD 2018, you should probably start with a Windows  partition of at least 64 GB's.  Which version of Windows are you planning on installing?  The age of your Mac might dictate which one you can use.  AutoCAD 2018 should run fine Windows 7, 8.1, 10.
Please let me know if you have specific questions on this install.
John Vellek
