- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When I render any lights, they appear spotty with a Lights & Material Render Accuracy of Draft and starry when I change the setting the High. Please see the attached images. The plane is teak, the solid sphere is paint, and the lit globe is frosted glass. I played around with lighting settings, changing materials, the shapes of lights, using different kinds of lights (including self-illumination), etc.
I've never had this problem before 2018. When I render the same scene in AutoCAD 2018 on my laptop, it's fine.
Thank you,
Jarrod
I also have the recommended driver version (375.86) as found on Autodesk's certified hardware page:
Card name: NVIDIA Quadro K4200
Driver version: 21.21.13.7586
Tuning Date: 1/31/2018
Virtual device: Dx11 (Hardware)
The card and driver meets the recommended requirement.
Display Adapters:
NVIDIA Quadro K4200(Primary)
Certification:
Hardware Available True
Hardware Recommended True
Status 2
Hardware ID 2
Hardware Feature Level 50
Software Feature Level 50
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Additional System Information:
ComputerSystem
Manufacturer LENOVO
Model 30AHCTO1WW
NumberOfProcessors 1
TotalPhysicalMemory xxx-xxxxxxxx
Processor
MaxClockSpeed 3601
Name Intel(R) Xeon(R) CPU E3-1271 v3 @ 3.60GHz
NumberOfCores 4
NumberOfLogicalProcessors 8
Revision 15363
OperatingSystem
Name Microsoft Windows 10 Pro|C:\WINDOWS|\Device\Harddisk0\Partition4
OSLanguage 1033
ServicePackMajorVersion 0
ServicePackMinorVersion 0
TotalSwapSpaceSize
TotalVirtualMemorySize 19189332
Version 10.0.16299
DiskDrive
Model SanDisk SD6SB1M256G1001
Name \\.\PHYSICALDRIVE0
Size 256052966400
DesktopMonitor
MonitorManufacturer (Standard monitor types)
MonitorType Generic PnP Monitor
Name Generic PnP Monitor
ScreenHeight
ScreenWidth
DisplayConfiguration
DeviceName NVIDIA Quadro K4200
DisplayFrequency 60
DriverVersion
PelsHeight 768
PelsWidth 1024
VideoController
AdapterDACType Integrated RAMDAC
AdapterRAM 4293918720
ConfigManagerErrorCode 0
CurrentHorizontalResolution 1920
CurrentVerticalResolution 1080
DriverDate 20161110000000.000000-000
DriverVersion 21.21.13.7586
InstalledDisplayDrivers C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvd3dumx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvwgf2umx.dll
Status OK
TimeOfLastReset
VideoArchitecture 5
VideoModeDescription 1920 x 1080 x 4294967296 colors
Process Information:
Loaded ARX and CRX Modules
acapp.arx
acapp.crx
acautoloader.crx
acautoloader.arx
acexperience.arx
acpublish.crx
acpublish.arx
AcPi.arx
acjscorestub.crx
acgsconfig.arx
acgsconfig.crx
acvmtools.crx
vl.crx
accloudconnect.crx
acconnectwebservices.arx
aclaunchnfw.arx
acsign.arx
acetutil.arx
vl.arx
acsceneui.arx
AcCamera.arx
acsceneui.crx
acdim.arx
acdim.crx
AcFdUi.arx
acvmtools.arx
acopmext.arx
acopm.arx
acobjclassimp.arx
AcOcSchemaUtil.arx
AcPEXCtl.arx
actp.arx
Effects:
ACAD_LineSmoothing supported turned on
ACAD_PerPixelLighting supported turned on
ACAD_AdvancedMaterial supported turned on
ACAD_FullShadows supported turned on
ACAD_TextureCompression supported turned off
ACAD_HQGeom supported turned on
ACAD_GlowHighlighting supported turned on
ACAD_Dx11 supported turned on
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Give this Autodesk Knowledge Network article a read and see if it helps
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your response. I increased the rendering levels, but it didn't improve the lighting situation.
I upgraded the other computer to Windows 10 1709 Fall Creators Update and now it is causing the same problem. I'm going to chalk it up to the Windows update that Autodesk said is causing problems.
