- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My autocad 2011 3d modeling file too big. Its 115MB
My AutoCAD 2011 created 3d modeling DWG file too big. its 115MB and hard to edit and make changes. So laggy. I also have AutoCAD 2018 student version.I opened it with AutoCAD 2018 and it takes 45 minutes. Also, I used purge command, DXF trick, Audit, Wblock, All of them none work.
I don't understand. How should I let this big size down? I attached my file pdf version for you just average size calculate.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous hello, have you try to copy and paste into a new file and see if helps. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
thank you for the reply. I tried. no luck. I also figured out one thing. In my drawing have 6 valves. I separated only one valve and deleted other things and saved. Size about 30MB. Next, I used UNION command and combined parts into one solid and saved then checked file size was only 80KB.
I really don't understand. I am also using AutoCAD only 3 months and don't know much more.
