yan.aquino
en respuesta a: john.vellek
Thank you so much but now I have a problem with choosing my scale because when I choose the scale I want to use and then insert my frame in the drawing the lengths of the lines done on the new drawing with the new scale are equal to the ones of the frame. I need to make each one of this pieces and put them in the frame with the dimensions and all but I am having trouble knowing what scale to use so it fits on the frame and what happens with the frame. ( the frame is black so it may be hard to see be careful it's origin is 0,0,0 ) ( also when I go to insert the frame on the block unit says millimeters but I draw it in inches) (also I don't know if it is because I'm inserting the file incorrectly )Frame autodesk .jpg
