john.vellek
en respuesta a: yan.aquino
HI @yan.aquino,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I see that @Bob_Zurunkle gave you some excellent suggestions to get you started on the right foot.
I made a quick video that shows how to check your units. I like to set the display accuracy a bit higher and show how you can still set the dimensions to only show a limited accuracy.
I also put a dimension in your model to show how the objects are 4*" apart.  This means you will need to change the scale of your viewport.
I like to apply a page setup for my layout so I don't have to set up plot settings all the time.  You will see that I select a print driver, plot style table and a paper size and that I will plot the paper at 1:1. (1"=1" 1 foot= 1 foot)
Next I open the viewport view of your model by double-clicking in it. Now I can select the scale from the scale list.
I hope this helps you to work through your class exercise.  Please add additional posts if you need anything more.
John Vellek
