mikogold
1003 Vistas, 7 Respuestas
Please help me find the way to design this C4D model in AutoCad
Hi, I am trying to convert a model that I have designed using Cinema 4d ( C4D ) to AutoCad but I can´t find the right approach.
I did it using the Subdivision Surface and Subdivision Weight commands of C4D, where you first draw a polygon then you assign different "tensions" or "weights" to the lines, dots, or planes of the object and then you smooth it achieving a rounded or more organic model.
Is there any command or way to achieve something like this in Autocad?
Thanks!!
This is the poligonThis is the poligonIn red the heaviest  part and blue the lightestIn red the heaviest part and blue the lightestfinal rounded modelfinal rounded model
