en respuesta a: john.vellek
3D solids in blocks have been assigned materials in acad 2018 through the matbrowser and/or the properties tab.
As I said in the other post, 1 of the files in a modification (save-as) of the other - basically a lot of objects have been deleted and some texts changed.
Upon save>close>open randomly some objects just lose their assigned material (from the autodesk lib).
Easiest way to see this is in the NL(C) layout - where no object should be displayed in an "autocad color".
I currently have about 30 of these files and only in some cases the materials stay put, and having to redefine the blocks on each before being able to work on them is rather tiresome - because this is basically just a bug.
(not as bad as the bug autocad has where if you have multiple camera's, delete one and try to rename another to the name of the one you deleted - fatal error)
(about as bad as the bug where the modelspace UCS is suddenly changing because you  have been in a 3d viewport in paperspace, so you need to reset UCS>W every time you check a view.)
