1019 Vistas, 6 Respuestas
Materials and saving
Does anyone have a real solution to the tremendous bugs that AutoCAD has with materials - other then not using AutoCAD or materials?
When you apply materials, save, close and reopen - the materials will randomly disappear, so you have to repeatedly re-assign them to objects.
I have some dwgs where they miraculously stay put and I use blocks and the design center to use "redefine only" to reapply, and reapply and reapply... every time I open another dwg (where random object changes have happened during save or open).... even if those files are save-as variants of the ones where the materials stay put.
This is getting tremendously tedious, so does anyone have any real solutions (except dropping this unsupported bugfest and going to another firm that doesn't charge for software they don't really support or develop anymore.).
Scripts to redefine all blocks upon open would do (but I have had no luck in making one myself; sorting through the blocks collection I can manage - but I have no idea how to (v)lisp material properties (just like Autodesk apparently :cara_con_la_lengua_fuera: ).)
Using AutoCAD 2018 (but same results in any previous version that "supports" the material lib) on 64 bit with NVIDEA GTX960M.
