Alfred.NESWADBA
en respuesta a: Amremad
>> now it's doesn't with new hatches
New information or changed information? Your screenshot shows "Hatch Edit" dialog ... which means you edit an existing hatch ...
For new hatches make sure HPASSOC is set to one, then start command _HATCH and create a hatch by "pick points" or "select" object(s). Finish the hatch command, select the hatch again and look to the property window, is the hatch associative?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
