Amremad
6534 Vistas, 11 Respuestas
hatch Associative property is disabled
Hello All
I have a problem with hatch in Autocad2018 after install AutoCad2018 plant 3d
i can't use Associative property with hatch where when i click on it's button make it disable , and i can't edit the hatch
imadHabash
en respuesta a: Amremad
would you try from command line to change HPASSOC system variable to 1 .
Command: HPASSOC
Enter new value for HPASSOC <1>:
Imad Habash
Alfred.NESWADBA
You can't re-associate a hatch to an existing boundary.
The setting "Assicative" for hatches needs to be activated before you create a hatch. Then the creation of the hatch will store the information about i's borders to the hatch object and so every modification of any of the borders initiate an update of the hatch.
Whenever you already have created hatches without the information about the borders you can't tell the hatch afterwards to find it's borders (they even might not exist any more) ... and that's why you can't activate the associative flag after the hatch is already created.
If that helps: you can create boundaries for a hatch (which are not the original objects, but new created objects) and for that function you can tell AutoCAD to regenerate the hatch to be associative to these new objects.
Hope that makes sense, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Amremad
en respuesta a: imadHabash
Command: HPASSOC
doesn't work
Amremad
en respuesta a: Alfred.NESWADBA
the boundaries of hatch was working, now it's doesn't with new hatches
Alfred.NESWADBA
New information or changed information? Your screenshot shows "Hatch Edit" dialog ... which means you edit an existing hatch ...
For new hatches make sure HPASSOC is set to one, then start command _HATCH and create a hatch by "pick points" or "select" object(s). Finish the hatch command, select the hatch again and look to the property window, is the hatch associative?
- alfred -
Alfred NESWADBA
imadHabash
>> I have a problem with hatch in Autocad2018 after install AutoCad2018 plant 3d  <<
i suggest to reset your autocad to default settings . >> Click <<
Imad Habash
Amremad
yes iam sure HPASSOC is set to one, and associative is yes
but see this picture
Alfred.NESWADBA
what object type is the border you selected to create the hatch?
Can you please select that border and show a screenshot with border and property window?
- alfred -
Alfred NESWADBA
Amremad
sorry about late Mr.Alfred.NESWADBA
Amremad
any solution ?
