en respuesta a:
03:23 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-23-2018
03:23 AM
Hello, I've my own solution and apparently that works:
_Open the Design center window
_Select your DWG
_Click on the blocks tab
_Do your operations, like Redefine a block.
_When you finish, click on another tab of the DWG, like dimstyle for example.
Apparently, if you less the Desing center on the blocks tab, Autocad needs a lot of memory to run.
Thank you.
