01-20-2018
06:02 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-20-2018
06:02 AM
>> The LIST command will at least tell you the bounds of it in all three directions, if that will serve:
Just want to add ... as long as the object is not rotated.
You get the orthogonal extents, which are then showing larger values in case the object is not parallel to X/X/Z
In case the object is rotated you might first use command _UCS to define a ucs you want to have as base for _LIST command return values.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
