- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
Your solid in the video was created by using an extrusion. Try using BOX to create the solid and then you will see all those properties. I am not sure why they don't display the same for geometry that looks the same but was created differently.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@john.vellek wrote:
HI @Anonymous,
Because a polyline in the shape of a square doesn't have WIDTH and LENGTH properties? Well a line and polyline have a length property but it doesn't mean the same thing for a polygon.
Ed
How to post your code.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The LIST command will at least tell you the bounds of it in all three directions, if that will serve:
3DSOLID Layer: "0"
Space: Model space
Handle = 1d0
History = None
Show History = No
Solid type = Extrusion
Extrusion height: 3.2500
Taper angle: 0
Bounding Box: Lower Bound X = 11.4434 , Y = 10.4203 , Z = 0.0000
Upper Bound X = 17.2093 , Y = 14.7613 , Z = 3.2500
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Just want to add ... as long as the object is not rotated.
You get the orthogonal extents, which are then showing larger values in case the object is not parallel to X/X/Z
In case the object is rotated you might first use command _UCS to define a ucs you want to have as base for _LIST command return values.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
