874 Vistas, 3 Respuestas
Automatic lines from left points to right ones
Does anyone know how to create automatic lines from left points to right ones as shown in the snapshots attached?
I have divided two arcs (right and left) into 160 segments. So, what I have got is these points which I would like link each other through lines/segments automatically instead of making them one by one.
Any thoughts would be appreciate .
Regards
Leandro
imadHabash
en respuesta a: Anonymous
i suggest to use ARRAY  command with known angle spaces that will achieve your need.
Imad Habash
imadHabash
i forget to say that with Array ( Polar ) you can get it by specifying and filling :
  • Items : specify the number of items .
  • Between : specify the angle between items .
  • Fill : specify the angle between the first and the last item in the array .
Imad Habash
Kent1Cooper
If those Points are from DIVIDE-ing two concentric Arcs in the configuration that would result from Offsetting one to get the other [whether you actually made them that way or not], then there's a way to do this without the Points at all.  You can put those Lines in place directly from the original Arcs, without  DIVIDE-ing them first.
Go and get DivideMeasurePlus.lsp, >>here<<.  Load that.
Draw a vertical Line of the distance between the Arcs, anywhere.  You can draw it between Arc ends, and ROTATE it to be vertical.  [It needs to be vertical, for the options described below, so that the alignment direction tangent to an Arc at a given location along the Arc will place each copy of the Line perpendicular to the Arc.]
Call up the DIV+ command.  Choose the User-Selection option [one of the major enhancements compared to ordinary DIVIDE], and select that Line.  When it asks for a "Base point in relation to selection: ", pick the bottom end of the Line.
Accept the offered default Aligned option for the rotation.  Give it your number of segments [160 in your example].  Accept the offered Standard default for placement in relation to the segment-division locations, and the offered 0 default for inset from the ends [another option regular DIVIDE doesn't offer], and the offered Yes default for placement at the ends [yet another thing regular DIVIDE won't do].
When it asks you to "Select object to divide: ", pick the outer Arc, anywhere.
You can get the same result from it in some other ways:  you can pick the top  end of the Line as the base, and pick the inner  Arc to divide;  or you can draw the Line horizontally, and use the Relative-angle to the path rotation option [another choice not available in ordinary DIVIDE], and give it 90 degrees and pick the outer Arc, or 270 degrees and pick the inner one.
Kent Cooper, AIA
