- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Can I upgrade my AutoCAD 2016 software? or must I uninstall and then install 2018?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
as long as you do have an active subscription you can leave AutoCAD 2016 installed as it is and additionally install AutoCAD 2018.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> Can I upgrade my AutoCAD 2016 software? or must I uninstall and then install 2018? <<
AutoCAD 2016 , 2018 area two separated versions . if you to install new version ( 2018 ) then you will have two AutoCAD version. so it depend on you how many version did you need to use.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
install new AutoCAD 2018 for more update so you can easily access the features of 2018 version and check out the update if updated features are good for you then install it otherwise use AutoCAD 2016.
Hope the above information is helpful for you.
