899 Vistas, 10 Respuestas
Cant drag objects with LMB (if not clicked the grip) and can't pan with middle
Hi, I cant drag objects with LMB (if not clicked the grip) and can't pan with middle button, can anyone help? The mouse is Logtiech M557 and all the settings are correct.
rkmcswain
en respuesta a: Anonymous
Please do a screencast so that we can see what you are attempting to do.
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
Are you selecting an object with no command active, and then LMB clicking on the object, and then trying to drag it?
Or are you trying to use the MOVE command to move an object?
en respuesta a: rkmcswain
I select an object with the LMB and am trying to move it - on Windows I can move an object by just dragging it (keeping LMB pressed) - on Mac version I can only move it if I drag by some grip point (blue square). I'd like to be able ie. to move the text annotation by just moving it holding LMB anywhere over the text, like on PC.
pendean
Go ask in the MAC forum why the MAC acts differently and if there is somehow a way to match them up https://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
Remember to list your AutoCAD for MAC version.
Here is the screencast: http://autode.sk/2DiKbQR
en respuesta a: pendean
I would think it’s not about the Mac / PC - on Mac it’s a new installation from today and I think it’s just some setting that’s default while that ACAD on PC has some different settings.
pendean
You'll never know if you don't go ask MAC users and hope only Windows users can address MAC functionality :cara_neutral:
TheCADnoob
AutoCAD on MAC is a completely different critter. On the surface it might see like it should t make a difference but i've been caught surprised more than once.
CADnoob
en respuesta a: TheCADnoob
I've read about same issues also on PC forums - but did everything and still it doesnt work. I will try on Mac forums now.
rkmcswain
(A) Turn OFF the lasso selection feature.
(B) On Windows, it take a 1/2 a second or so to "grab" the object for moving.
pendean
For anyone else in the future stumbling on this post...
"This feature is not available in AutoCAD for Mac." https://forums.autodesk.com/t5/autocad-for-mac-forum/cant-move-drag-objects-with-lmb-on-and-cant-pan...
