Kent1Cooper
en respuesta a: leeminardi
@leeminardi wrote:
To delete trailing zeros you may need to write a custom vlisp program that examines the text string of the coordinate from the last character backwards and deletes it if it is a zero and until the first non-zero number or the decimal point has been encountered.  Perhaps there is such a routine already available that you can find via a web search.
Not necessary.  Set DIMZIN appropriately [to 8 or 12] and get the strings without the trailing zeros right from (rtos).
Kent Cooper, AIA
