leeminardi
en respuesta a: Drewpan
I've edited your program to include a z coordinate and output all three coordinates on the same line.
(defun C:LP(/ PNT1 P1X P1Y STDY DY COORDN COORDE PTXT)
 (setq PNT1 (getpoint
 "\nPick coordinate point: "))
 (setq P1X (car pnt1)) ;x coord
 (setq P1Y (cadr pnt1)) ;y coord
 (setq P1Z (caddr pnt1)) ;z coord  <--
 (setq STDX (rtos P1X 2 2))
 (setq STDY (rtos P1Y 2 2))
 (setq STDZ (rtos P1Z 2 2))
 ;;;(setq COORDE (strcat "X " STDX ))  <-- remove
 ;;;(setq COORDN (strcat "Y " STDY ))  <-- remove
 (setq msg (strcat "X " STDX ", Y " STDY ", Z " STDZ))
 (setq PTXT (getpoint
 "\nPick text location: "))
 (command "LEADER" PNT1 PTXT "" msg "")
 (princ)
To automatically load the program when you start up AutoCAD go here.
The program will work in 2D or 3D but will always output a Z coordinate.
To delete trailing zeros you may need to write a custom vlisp program that examines the text string of the coordinate from the last character backwards and deletes it if it is a zero and until the first non-zero number or the decimal point has been encountered.  Perhaps there is such a routine already available that you can find via a web search.
BTW, are you familiar with the coordinates command?  If not, try it out!
lee.minardi
