gotphish001
en respuesta a: gotphish001
Your leader style can have many sections. There must be some sections of zero length. I know they are zero length because when I explode the text it goes back to text but when I window select around it then it only shows text and no leaders. Explode the text and it goes from a multileader to Mtext and then it mirrors correctly.
Edit:  I'm not sure why but it changes the alignment to top center from center when you explode it. I'm not sure why it must have something to do with how the multileader is set up, but it can be changed easily if needed.
Last Edit: If you have a multileader and select it then right click and option remove leader, it still remains a mulitleader object which is what you have. That had to be what happened as I was unable to produce a multileader with a leader of zero length. Fix is the same though. Just explode it to MText.
Nick DiPietro
Cad Manager/Monkey
