01-12-2018
07:59 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-12-2018
07:59 AM
I can reproduce the issue. If you use text with a center grip and put spaces before the actual then it counts the spaces for the mirror. It will mirror the text based on where the text grip is. Click on the text. Is the grip in the center of the text or off to one side. If it's center aligned text and the grip is off to the side then there are spaces that are not needed. Remove the spaces and the grip should go back to center of the text and mirror should work correctly. That is at least my guess without a dwg file. If that doesn't fix your issue then upload a dwg so we can test your actually drawing. Pictures are great to illustrate a point or question but are lacking as you can't test them.
Nick DiPietro
Cad Manager/Monkey
